SOURCE: Need Instruction Manual for Saeco Magic Comfort Plus
http://products.saeco.com/index.asp?id_paese=7
follow the link to the instruction manual
SOURCE: got an old saeco magic comfort 7/8 years old -
You are correct to descale the machine. I am not sure how "decalcification" is different, but if the message is still coming up, you may need to have some repair work done. There are some sensors inside that can be cleaned manually if a descaling solution doesn't do the trick. You can do some work if you are mechanically inclined.
SOURCE: Rinsing...Warming UP... message on Saeco Magic Comfort plus
HI, I am sure you have solved your problem, however:
If you Descale the machine and let it Rinse to complettion of the
cycle; it resets the machine and it will start Rinising after warmup.
Otherwise press the Menu button and go to Energy Saving
then press the Esc buttton. This allows the machine to start
without Rinsing. Also you may turn Rinsing to Off in the Menu.
SOURCE: Saeco Magic Comfort plus: Despite descaling the
Hi
In the menu there is a program below the descaling program that says Reset descale. Enter this program and choose "yes", and make sure that you push the enter button to lock your answer. If you don't it will still be there.
Also go to your water hardness and move it to the #4. This will prevent you from having to replace the boiler sooner than needed. Descale when told to by the machine.
Testimonial: "Fast, correct and thorough. The cryptic Manual was less than clear but your instructions were excellent. thank you"
SOURCE: the coffee grinder on my Magic Comfort Plus is not
Hi Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute. Once that is cleared go to the bean hopper. There is a lever under the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time, but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
