Siemens Efficient Networks SpeedStream 2623 (SS2623) Wireless Router Logo
A
Anonymous Posted on Jul 06, 2014
How can i know or change the main password for administrator. I cant access main page for Siemens Gigaset 504 AGU, because he inform me that password is invalid although on the default generally password is '' admin ''
Indermani Tiwari
Level 2:
Habit-Forming:
New Friend:
  • Expert 36 Answers
  • Posted on Jun 03, 2017
Indermani Tiwari
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
36
Questions
0
Helped
22689
Points
106
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa
5 Related Answers
Anonymous
  • Posted on Nov 19, 2009
SOURCE: Wireless LAN not active
loptop not connect to router as wireless
Anonymous
  • Posted on Oct 21, 2010
SOURCE: Siemens Gigaset 504 AGU,, wireless lan is not
I have forget my wireless pass word and how do I recovery or change for new pass word?
puertobori
  • 7733 Answers
  • Posted on Mar 21, 2011
SOURCE: why my Siemens Gigaset 504
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Anonymous
  • 32281 Answers
  • Posted on Jun 17, 2011
SOURCE: My laptop doesn't detect the
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Testimonial: "Thank you sooo much for your prompt assistance!! Now my laptop detects my own wifi connection with the Siemens gigaset router! ;)"
Anonymous
  • Posted on Aug 09, 2011
SOURCE: how to configure and set up gigaset 504 agu
ican password change and wirless signal on
Gigaset 504 agu
power up your modem and connect to your computer directly with an LAN cable.
open your web browser (internet explorer)
type 192.168.254.254
and enter
you will be asking for administrator password which is normally "admin"
hope this answers your query
1helpful
Hi there I have a gigaset 504 agu router and my
Its means that 11 people are using you're router. I would turn on WPA or WPA2 security on the router, and put a password on it, then use whats called MAC address filtering so it only allows you internet access. Also disable WPS if you can because it can be hacked easily.
1helpful
2answers
8helpful
2answers
How to change password in gigaset 504 agu
How to change my Gigaset 504 Agu wirless password
I need to secure my gigaset 504 AGU, i put password on my router wifi but still i have a Enabled 50 clients,on my wireless network
you have put password for accessing your router( system config menu/router config menu) but not client WEP password, the router is still open access point( AP). configure a WEP key and then each/any of the client need to know this key/password to access internet via your router. good luck
1helpful
I have a siemens gigaset 504 AGU wirless router. I moved to a new apartment and changed my land line and internet company provider. Connected my router and wirless network was detected and connected...
Gigaset 504 AGU black color signal antenna . How to find (Host Name) and only showing there mac address ans ip address. i want see witch one using my net and we want fine friend computer name in my router .
1helpful
2answers
Siemens Gigaset 504 AGU router password and email adfdress forgot. How can open this usb modem. before it was working in uae etisalat.than
You need to made it to default factory reset by pressing a few seconds on the reset button in the bottom of the devices. When it restarts it will be looks as new and you should re configure the isp settings of your internet connection. That's all. Before you make reset, don't forget to save the configuration to your computer for the future. Because if it is not working when you made the reconfiguration, you can also install the configuration from this configuration file.
2helpful
5helpful
2answers
Top Siemens Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
