Read owner's manual
Lexmark Lexmark X8350 Owner Manual
SOURCE: LEXMARK X8350 COPY,PRINT,SCAN AND FAX
I do so apologize for the problem during our chat session. One second I was typing in the next step and then suddenly the chat program wouldn't send my chat, and the top of the window said server error.
I would have contacted you before but I did not remember your user name until the website management gave me the info.
If you still do not have your printer working, please download the vista driver here (note where you download the file to.)
Then make sure your printer is not connected to the computer.
Double click the driver file you downloaded to start installing the driver.
When the install asks you how the printer is connected, reconnect the USB cable to the printer and pc.
If you have any other problems with the install, just let me know.
And again I apologize for any inconvenience the interrupted chat session may have caused.
SOURCE: How do I clean my Lexmark X8350 printer heads?
Was able to download the manual at no charge and found solutions on pages 96-98.
SOURCE: is the lexmark X8350 campatible with my new Apple iMAC?
No i don think this printer is compatible with Mac because it doesnt have the downloads for it on the website also......But i would request you to have a chk with Lexmark they may have CD for it.....
Good Luck
For technical support or customer service in
North America,
1-800-LEXMARK (539-6275)
SOURCE: change default ptr setting for lexmark x8350
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
SOURCE: Lexmark X8350 "communication not available"
I fixed this by completely uninstalling the Lexmark software, then unplugging the USB and restarting. I then installed the new Lexmark software that I downloaded from their site, make sure not to plug the USB back in until it told me to. It then detected the printer properly and started working.
