When you press the button for coffee, the water comes out of the milk frother
Did you cheak if the spots are blocked did you run some clean water ? The milk further is a different section from the coffee try and consentrat on the coffee part run some clean water is there any noise is the water going in to the trip tray because the spout are blocked ? Next go inside and cheak driver relay or seloniod stay safe if you not such don't do it
SOURCE: no coffee coming out, just hot water
Two questions:
1- Is the coffee grounds wet or dry?
2- Does the spout drip water when the machine is just heating up?
If the grounds are dry then the brew chamber is not getting any water. Turn machine off, let it cool down, then remove brew unit. Behind the brew unit there is a white valve with 2 red o-rings(sometimes black), if you look closely there is a small lever between the o-rings, get a small screwdriver and gently lift lever and spring, if water came out then the problem is in the brew unit, unscrew the stainless steel screen which is under the large red O-ring on the brew unit and clean, also make sure the tube on the unit is clear.
If the hot water spout is not dripping when the machine is heating up then you're good.
SOURCE: water will only dispense out of the frother.
It could be several soutions to this problem. First of all, try to clean the sieve in the brew unit, it may be clogged. Take out the tray, in between the 2 brown "lips" inside you can put your finger up and clean out all the old coffeegrounds stuck up there. Then put everything back in place and run a Rinse machine operation.
If this is not helping, listen out when you start up the machine; You should hear that the valve is turning 3 times, if it doesn`t it can be a problem with this valve not opening in right position. Then all the water would go out in the tray, and not into the brew unit. That maybe can be solved by changing this Multi ceramic valve or the Main Electronic board. Then it`s a job for a sertified Jura technician.
SOURCE: Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
SOURCE: All water directed to Frother/ Water nozzle on Impressa C%
The Multivalve seems to be stuck. When you start up the machine you should hear the multivalve turning 2 times, if it`s silent, the valve is defective. This valve is important to guide the water in the right direction. Contact your servicedealer and let them have a look. There`s also a small chance that the electronic board are sending wrong or no signals to the valve
SOURCE: no water is pumping thru the water spout or the
I got this machine and there was grinding noise but no water coming from the spout or coffee from the dispenser.
Took the back cover off. The big lump in the middle is the water pump. One of the wire connections was hanging off mine. Pushed the connector back on and everything worked fine.
Great coffee, rubbish construction!
- Make sure that the filled water container is in the appliance.
- Turn the program selector to "On" with lighting and place a container under the hot water spout and another
under the steam spout.
- Press the hot water button, turn the steam selector counterclockwise and dispense hot water until it flows in
quiet, continuous streams.
- Press the hot water button again.
Turn the steam selector clockwise to o, to turn off the water.
If this doesn't do it for you, you are doing it wrong!
