There are a couple of microwave ovens out there where after it has finished cooking, the light and fan continue to run until you open the door. Then the fans shuts off, but the light remains on. When you close the door, then the light shuts off. If the light and fan go back on when you close the door, then you have a bad door switch.
I can't tell without more exploration what may be the cause, but 1st let's start fresh. Reset the MW by unplugging and replugging the unit. Then set up the clock, etc by following the manual. For reference, go to http://www.emersonradio.com/resources/owner_manuals/manual_1313021007.pdf for instructions. There are many interlock micro-switches that must all work when the door is closed. Take one step at a time, then come back.
you mean it want power up or want work when you press the star buttom?
1. check the fuse if no power.
2. If it doesn't work when closing the door after setting timer it is the micro switch that the metal lach hits when the door close.
3. unpluge the micro wave unscew the scews to the cover of the microwave remove the cover. up front by the door you will see the micro switch maybe (brown,black,white,red/white ) what ever color it is disconet it take it to the hardware store buy a new one and replace it,themreasemble your micro wave.
This is a list of possible causes. 1. Defective triac or relay 2. controller is confused (pull power cord for a minute and see if it resets) 3.Defective controller or touchpad.
I still suspect a bad door switch or door switch mount, but it may be a stuck relay or bad conneciton on thew control board.
We have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
The Problem you Having is dirty Door Switches,Get some Electronic Contack cleaner from the Hardware Store,Make sure it has the little straw to Extend the Spray,Open the Door of the Microwave Look at where the Door Closes youll see Tiny Micro switches,*Note UNPLUG POWER FIRST
One of the things that well cause that to happen is the voltage Reg. sticking close. thats only one thing there are 7 others that well do that you need to find a electronic Tech who can look at it for you.
