Washing Machines Logo
A
Anonymous Posted on Jul 06, 2014
Why is my affinity dryer not heating and showing error code 56
  • Official Brand Answer 2,267 Answers
  • Posted on Jul 10, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1289912
Points
2557
Good Afternoon Friend,
I understand your Frigidaire dryer, model# ATF7000ES, is not heating and showing an error code 56. The E56 code means there is high motor current, meaning it is possible something is going on with the motor. The other possibility is this is a false error code. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
4 Related Answers
A
Anonymous
  • Posted on Sep 09, 2007
SOURCE: AFFINITY ERROR CODE
door not close
Anonymous
  • 111 Answers
  • Posted on Jun 18, 2009
SOURCE: Dryer shuts off, no heat, AD code
During normal operation, the display may show: “ad” - dryer is in an auto dry cycle. “dn” - cycle is done in auto dry. “PF” - a power failure to the board has occurred. “Err” - an error has been detected. “LOC” - control lock is activated. “PAU” - cycle has been interrupted.
Anonymous
  • Posted on Sep 26, 2009
SOURCE: Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Anonymous
  • Posted on Feb 21, 2011
SOURCE: Frigidaire Dryer Error E 04
I have the same problem. Does anyone have an answer?
What do error codes FDL and R11 indicate?
Hello Lidia, thank you for your inquiry!
Based off the information you have provided your Frigidaire dryer is not heating and displaying error codes "FDL" and "RL". I am showing that the codes you have provided are not valid error codes. I would recommend performing a reset on your dryer and you can do that by disconnecting power from it for at least ten minutes. I see that you have already replaced the igniter; however, if you continue to have issues with the error codes I would suggest having a professional technician out. This will help you avoid any further unnecessary part purchases. Hopefully this information is helpful to some degree. -Matt
2answers
Dryer wont heat up
I understand that you are having trouble with your Frigidaire Affinity dryer not heating up. There are some things that you are able to try. First check to make sure that the lint filter, the ducting, and the outside vent, are clear of lint and not constricted in any way. Second, reset your appliance by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. Once power has been restored, run any cycle. If you are still noticing that your dryer is not heating, I suggest contacting your local authorized technician for further assistance. They should be able to diagnose your dryer and determine why your appliance is not heating. Hope this is helpful.
-Best Regards-
WP
1helpful
Frigidaire affinity XD71702132 error 68
Please click the link below to see my answer to a similar E68 question on fixya:
https://www.fixya.com/support/t10225683-error_code_e68_frigidaire_affinity
1helpful
you have a problem with the heat you can't just say it's the element or thermistor you have to unplug it,take it apart and get in there with a meter and check all the t-stats,element thermistor,if they check good you could have a bad computer board but hopefully it will be the element but if you just bought it the dryer is still under warranty for the first year so either call whoever you bought it from or the 800 number off of the machine
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
