SOURCE: Error code C-2152 on C351 Bizhub All in One printer
C2152: Transfer belt separation
it seems that it the you transfer belt. to be sure, take the old one into the copier, swith off th copier, with 10 seconds or more, then swith on. the error code will disappear :-)
SOURCE: how to set scan for a new person on bizhub c351
If you know the ip address of the copier printer, it will be easier for you to add e-mail address. open the internet browser and type in the ip address. admin password 12345678. or use public. Click the scan tab.
SOURCE: Konica bizhub C351 with a C9401 error code
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
Check the flat cable for proper connection and
correct or change as necessary.
Change PWB-C.
SOURCE: how do we change the language on the konica minolta bizhub c351
1) Press "Utility-User Setting-Language Selection
2) Go to service mode System 1 - Marketing Area - US
You have to do both
SOURCE: Malfunction Detected code C-12CB konica Minolta
Hi bellotasuelt,
I can't find any reference to that code in the Bizhub C250 Service Maunual.
Having said that, all C-11xx codes relate to the finisher/sorter.
Try opening and closing it. Have a general look in the finisher for jammed paper.
Make sure nothing is obstructing the unit from moving.
Sorry I can't be more specific.
Good luck.
