This is all the Bentley shows:
Location: Driver's side door trim in storage compartment.
Removing:
- Remove driver's side door trim:
Repair
Manual, Body Interior, Repair Group 70 - Unplug connectors.
Carefully disengage catches -arrows-.
Press switch for interior monitoring and towing protection -1- or trunk release
switch -2- out of trim toward rear.
Installing
Installation is carried out in the reverse order.
Remove trunk lid lock.
Repair Manual, Body Exterior, Repair Group 55
- Use a flat screwdriver to pry plastic tab -3- off retaining
pins -1-.
- Bend plastic tab fully to rear.
- Pull contact switch -2- first sideways and then up and out of
trunk lid lock.
Installing
Install in reverse order, paying attention
to the following:
Note:
Make sure that washers are correctly
seated between plastic tab and trunk lid lock.
