Northstar Pressure Washer 3000 PSI Logo
A
Anonymous Posted on Jul 05, 2014
Haven't started washer in 3 years. What should I do besides new gas. It's a workforce 2500psi, 163cc. Lost manual can see where choke and throttle are.
1 Related Answer
john andrew manchook
  • 755 Answers
  • Posted on Jul 19, 2010
SOURCE: I can't find my manual and no longer remember what
Does your pressure washer engine have a place to add and check the oil level? If it does. And it looks like the picture from your question. It is a four stroke engine and the fuel doesnt need added oil.
Northstar washers are available online at Central Power Equipment.
You might find an electronic owners manual there.
How do I print the manual for the Manual for workforce 2500 psi 163cc pressure washer
with a printer ...first you have to find the manual. try google
May 07, 2021 • Psi Garden
ProForce PWC102350 2,350 PSI 2.3 GPM 163CC MagnaForce Gas Powered Pressure Washer will not start
If you have compression then the first thing you check is for spark. If you have spark then you move on to the fuel system. You will have to pull off hoses at a couple of points to see if gas is at the carb and further along. If it is the carb then a simple carb kit will work.
Carburator is gummed up I can remove the carburator but after that im lost I removed the screw from the bottom of the cup drained the old gas shot some carb cleaner in there opened the gas line put the...
leaving fuel in a bowl will cause corrosion in the jets and jam the needle and seat operation
take the carby off the machine and go to a shop that can overhaul the unit
I can't find my manual and no longer remember what the fuel mixture is for my workforce 163cc power washer. Can you help me? Thanks much.
5helpful
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
2answers
Throttle switch moving
Trace the throttle cable, it probably has a loose mount/clamp somewhere along its length.
4helpful
Can't start the Honda GX160 5.5 HP Electric motor on my Chore Master 2400psi Pressure Washer. Got gas (checked through feed line), new spark plug, switch on, gas, choke ok, throttle a bit funky (about 12...
Is there an oil sensor unit if it is going bad it tells the engine the oil low and engine wont start. I had same problem with my pressure washer, i just unplugged the sensor unit and it started fine ever since
Apr 27, 2009 • Garden
1helpful
Stihl KM 55 won't start
1. 1st change the spark plug to NGK BPMR 7A.
2. Set the kill switch to on position (I)
3. lock the throttle interlock on
4. Do not prime the fuel bulb...this may cause flooding.
5. set the choke to full choke.
6. pull the cord gently until the piston resists then pull hard
7. repeat pull a second time
8. open choke all the way
9. pull cord again hard.
engine should start within 2-3 pulls, release throttle and feather the throttle until stable
Apr 04, 2009 • Hand Tools
Top Northstar Garden Experts
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you a Northstar Garden Expert? Answer questions, earn points and help others
