Question about Akai LCT2715 27 in. LCD Television
Changing picture size on akai lct 2715. Without remote won't fill screen
SOURCE:
freetek
  • 5569 Answers
SOURCE: akai LCT 2715
This problem is with fair certainty the power supply.
Modern power supplies are designed to shut down if the current drawn exceeds the design level which indicates that something the supply services or the supply itself has died.
If you are adventurous, you might pull the plug on the set, gain access to the innards, and with good light, inspect any boards inside. If you see one that has few ICs but many more larger discrete parts, this will be the power supply.
You are looking for components called electrolytic capacitors that are almost always cylindrical and mostly installed upright at 90 degrees to the board with leads passing through to the solder side.
This same type of component in smaller dimensions is also still used in a horizontal package with leads bent down and passing though holes to the solder side.
The latter are becoming more rare since they don't lend themselves well to robot assembly.
Many (not all) will show signs of pregnancy when they fail, bulging unnaturally when compared with others. Now and then, there may be traces of a crystalline deposit around the end where the seal failed from internal pressure.
These will have values listed on them in uFd & VDC and sometimes, a plus/minus number lying about the precision.
Some also have a date code (rarer) that will look like four digits:
2403 = 24th week of 2003
Most electronics suppliers have a stock of the various values but if they have a date code at all, try to get only those made before 2002 or after 2006. The caps made between those years may be bad when new.
The larger caps will probably be OK since the failure is likely related to functions other than brute-force filtering. A pretty good 'rule of thumb' is to replace any caps you see bulging that are 100 uFd or less. If you don't mind a few nickels more, insist on 'low ESR' capacitors.
If you choose to replace these yourself, you will need a quality soldering iron with a small, preferably iron-plated tip, rosin core solder and a sponge which when wetted is used to frequently wipe oxidized solder from the tip this should be kept bright and clean and fresh tinning will keep it that way.
You should also buy some solder 'wick' with the iron; this is used to place on the solder you wish to remove and then heated with the iron. Properly used. the wick will absorb nearly all of the solder from the lands from which you wish to remove a component.
A good source for any of these things is http://www.mouser.com/  They have a huge inventory of parts, fair prices and no minimum billing.
Posted on Sep 16, 2008
SOURCE: Akai LCT 26AE Universal remote codes for RCA remote
i cannot find the model # to my akai tv/dvd combo where is it? AND ALSO I DO NOT HAVE THE REMOTE TO IT LOST IT DURING MY MOVE. HOW CAN I PURCHASE I NEW REMOTE OR WHICE UNIVERSAL ONE SHOULD I BUY! PLEASE HELP
Posted on Nov 12, 2008
  • 2337 Answers
SOURCE: lcd akai 2715 blinking red light
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Nov 27, 2008
SOURCE: accessing user mode on my AKAI LCT 2715
On my Akai LCT2715---- Ok, I had the same problem with locating USER MODE (even called Akai service HELP and that person didn't know anything)!!! even tho we looked through manual just got TV back from putting $184 in Capacitors repair (PUT IN NEW NICHICON CAPACITORS) from the standby button not woking just flashing from the Power Supply gone bad plus 2 main capacitors other than power supply that were bad. Works great now. For the USER MODE look on the remote in the bottom black area repeatedly push the P.MODE. You should have full function to adjust all in menu list WE DID.
Posted on Mar 19, 2009
  • 2337 Answers
SOURCE: I have a lct 2715 not too long ago the screen went black and the
The failure with your LCD might be due to defective capacitors in the power supply. These parts become defective due to excessive heat and fail prematurely If you are able to DIY, you can check the picture to see how defective capacitors look like.901ae86.jpg
Posted on Oct 02, 2009
I have a AKAI LCT 2060 TV, cannot see picture, only sound
This problems,i fix alot models of tvs all diffrent models of tvs but have the same board alway dies.The LCD inverter board is dead.This board help the LCD to have a backlight to go through the Turner board to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.The board is long in shape.It the easiest board to replaced in LCD tvs.
May 07, 2010 | Akai LCT2060 Television
Picture size mis too large. No matter what screen ratio or zoom setting, the picture borders are outside the screen. AkAI tech support phone # is no longer in serrvice.
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected. Some Dish Network boxes have Size buttons on their remotes and also in their main menu. It's difficult to determine the repair without knowing the types of the peripherals. Hope this helps.
Jul 30, 2007 | Akai LCT3201AD 32 in. LCD Television
I fixed the power supply but don't have a
akai LCT2715 keeps shutting off or making a loud screaming noise that can only be turned off by shutting it down at the the tv
Dec 21, 2009 | Akai LCT2715 27 in. LCD Television
I have a lct 2715 not too long ago the screen went black and the power light blinks yellow
Oct 01, 2009 | Akai LCT2715 27 in. LCD Television
Akai LCT 328STA,Comes on Akai screen appears then goes off.
Akai LCT 3285TA (notice the "FIVE") uses the MLT169A Power supply. This is available from shopjimmy.com for about $100.
Jul 22, 2009 | Akai LCT3201AD 32 in. LCD Television
Accessing user mode on my AKAI LCT 2715
Jan 24, 2009 | Akai LCT2715 27 in. LCD Television
Lcd akai 2715 blinking red light
Nov 19, 2008 | Akai LCT2715 27 in. LCD Television
Nov 02, 2008 | Akai LCT2715 27 in. LCD Television
AKAI LCT 2715:
Its busted. Try resetting it as a last resort, unplug the AC, wait 1 minute, then plug back in. If that doesn't work, its in need of professional service.
Jul 17, 2008 | Akai LCT2715 27 in. LCD Television
I want a Universal remote for an Akai LCT 2715 any suggestions?
try going to www.replacementremotes.com to see if they have the exact remote as some universals remotes don't work the set completely . Or you can see if they have the replacement remote that would work for your set .
Mar 04, 2008 | Televison & Video
Akai LCT2715 27 in. LCD Television Logo
35 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
