Hi i have hp window 8 i forget the passward and also account what can i do coz my computer needs account and passward
If you've forgotten your Windows password, there are several ways to retrieve or reset it:
What to do if you forget your Windows password Windows Help
SOURCE: i have had brain surgery, my short term memory is
Use Firefox.The browser give you the option to save your passwords.Here is the link.Once you start to go to any website that require a password Firefox will prompts if you want to save it.
Dear Victor,
For downloading driver software, please visit the HP
site page : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=3651156.
On this page, please select your OS and click next. Now, there will be
option called "Driver - Product installation software" section, expand
and select appropriate version you need to install and you will be taken
to download page. Before installing, just remove previous software, if
installed (recommended).
SOURCE: How to do if locked out of Windows 8 laptop?
1.
Run "lusrmgr.msc" to reset Dell Windows password.
In
Windows 8/7/Vista/XP, there is an easy way to reset a forgotten user account
password by just run the lusrmgr.msc. But you need to login your server or
laptop with an account which has admin privileges. Note that resetting password
with this tip might cause irreversible loss of information for the user
account. This data loss will occur the next time the user logs off. You should
use this command only if a user has forgotten his or her password and does not
have a password reset disk.
Step
1. Start your PC and log on with an available user account
Step
2. Click "start" button, press "Win+R"
to open "Run box". Type in "lusrmgr.msc"
and hit Enter.
Step
3. Local Users and Computers appears, all user accounts of
your computer will be list, right-click your user name and select "reset
password".
Step
4. Type in a new password and type it again to confirm it,
click OK.
After
restarting you can login that user account with new password.
2.
Remove Dell password by using a Windows password recovery tool.
This
is a universal way to reset forgotten Windows password on HP Server or PC, no
matter what your Windows system is, Windows 8/7/vista/XP. iSunshare Windows
Password Genius is designed to recover Windows password for any kinds of
PC, such as hp, dell, acer, Toshiba, Lenovo, IBM etc. It not only can help
reset server or laptop password Windows 8, but also Windows 7, Vista, XP and
Windows 2000.
Step
1: Download and install Windows Password Genius Advanced on
another computer you have access to.
Step
2: Run the software to create a Windows password recovery
disk with CD/DVD or USB drive.
Step
3: Insert the Windows password recovery disk to your PC or
Server and set the laptop to boot from the disk by changing devices boot order
in BIOS SETUP.
Step
4: After boot from the password recovery disk, Windows
password recovery tool will start automatically and display a friendly window.
Then you can reset whichever account password of your PC or Server by a few
clicks.
Windows
Password Genius also allows user to create new admin account for your Dell
Windows system without logging. With this new user, you can login your Dell computer
directly and access control panel to reset other user password.
SOURCE: forget my computer password,how can i brake
If you have a repair disk, of course you can try it to crack Windows password. But if you don't have maybe you can consider using Ophcrack. Most time it is helpful but cannot guarantee 100% successful reset. Above all, the last one should be the best method for your Windows password reset. Another safe and effective software you can try, Windows Login Recovery, which I have used and you can visit from:
http://www.windowsloginrecovery.com
