SOURCE: not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
SOURCE: Not Optimum Mode Recommended Mode 1280X1024 60 Hz
Add a 50 ohm between pin 5 and 6 of the NT68F63LG IC.
Go to this link to learn the details. http://translate.google.com/translate?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&sa=X&oi=translate&resnum=3&ct=result&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220
I tried this fix on my monitor and it works now.
SOURCE: not optimum mode recommended mode 1024 x 768 60hz
Hook up a different monitor and set resolution to no higher than 1024 x 768. Samsung monitor will then work fine. It appears that something fails in the monitor and it will no longer support anything higher than this.
SOURCE: screen goes blank then displays Not optimum mode.
Change your screen resolution to 1280x1024 or lower than that.If that too doesn't work log on in safe mode and restore the system to an earlier time.
SOURCE: floating box non optimum mode recommended mode
You need to adjust the Display screen resolution.
