No memory for settings
SOURCE: Sony STR-DE445 protect displayed
It sounds like a bad solder connection. It just needs to be soldered up, if you take it into a shop just tell them it doesn't need any new parts, it just needs to be soldered up.
Or, if you can solder it yourself, or know someone that can, that would be much easier.
SOURCE: My reciever is flashing the
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
SOURCE: cant get sony sub woofer model no. ss-wg60 working
First, go into the "setup" mode of the receiver and go to speaker select, then toggle to sub, highlight and make sure it's "on" Then toggle to speaker volume and check the sub level. Maximum setting is "0". Make sure you are connected to the subwoofer output on the receiver as well. If you still have a problem, post a comment and I can help you some more.Hope this helps
SOURCE: Trying to use a passive subwoofer with STR-DE445
The output of the Sony is "signal only" not power. Being "passive" like your sub. What you need is a sub amp, and they are not cheap, 400-600 on average "min". Unless you have a Velodyne 15 or 18, just get an amplified sub, they start around 150 new. Hope this helps
SOURCE: i have a sony str de445 and it overheated one nite
you might have burned up some internal parts, it is very important that you keep your unit well ventalated so that it has less of a chance at overheating, check for any internal fuses that might have blown.
