Have taken plastic cover off and recoil wiped off oil but cant see a exact oil trail. within 10 mins running time oil appears .
SOURCE: Toro Recycler 6.5 190cc 22
fuel bowl or pick up tube from carb to tank might have water in it
SOURCE: what weight of motor oil does the Toro Recycler 22
Assuming a 4-cycle engine, SAE30 oil. NO multigrade, unless below 0F, in which case 0W30.
SOURCE: toro recycler 20017 is very
The carburetor may need to be serviced. You need to find a parts shop that handles Tecumseh parts. You will most likely need a rebuild kit for the carburetor. The carburetor part number is 640303. The rebuild kit is 632809. The Tecumseh engine company shut its' doors 3 years ago. Finding parts is becoming harder and harder. I've heard that someone has bought Tecumseh over the winter but it is unknown when the new parts will hit the market. Best of luck to you.
SOURCE: have a toro gts recycler model #20007 cant find
should only be one bolt in center usually 5/8" , an Impact works best..less chance of getting cut!
SOURCE: starts and runs great(when engine is
I would check the gas cap. If the gas cap is plugged or pieces missing from inside it will not allow air into the tank and the fuel will not flow properly to the carburetor. Just loosen the cap and try it, if it does not change check for dirt in the fuel line.
