It was working fine. Went to turn it on, no light and wouldn't start. check the breaker and the outlet their fine. Took the tray out and hit the reset and then tried again, nothing.
SOURCE: my maytag m3dh30b2a dehumidifier trips the breaker
sorry it sounds like the compressor has locked up. Cost prohibitive to repair
SOURCE: My dehumidifier will not turn on. No lights.
Dehumidifiers have a float switch in the collector whichturns unit off to prevent overfill. Check it out and make sure it moves freely.Many dehumidifiers have a safety device which senses when the reservoir isfull. The tank either presses against a switch, or there may be a sensorconnected to the tank that triggers a switch when the tank is full. This is toprevent any water damage to your property. Always remember water andelectricity does not mix well. Empty the tank. This should solve the problem ifthe tank was full. If you empty it, and the unit still doesn't run, look aroundthe tank to see if there's a switch or other device that controls thedehumidifier. Look for a bucket switch. You may be able to throw a switch by hand. If all the above is ok then thecontrol board has most likely failed and unfortunately the manufacturer hasdiscontinued the production of parts for this unit. The board is no longeravailable.
