Does this give me full control of the tracks in the VS 2480
SOURCE: I need to find a place to buy one roland vs 2480 cd replacement fader board
You should contact Roland to find out who their parts dealer is for your area. Once you are on their site, click on the Support tab.
http://www.rolandus.com/
Jerry G.
SOURCE: how do i use the
You can't. Best way is to set your FX on your track. Hit sampling button, then go to the Resampe tab, hit start, run your track, save sample, load it back up. Not exactly how I woulda set things up, So I make everything dry on the mv and dump into my DAW for FX...Not sure what Roland was thinking with this little gem, but hit up MVNation.com...best site for info on the MV. After I found this site, I threw the manual out. Hope it helps.
SOURCE: When I turn on my
Have you tried to do a factory reset?
Hold SHIFT and press F4 (Utility). Press PAGE to get to page 3. Press F6 (PrmIni). Press F5. Press ENTER/YES
SOURCE: Roland VS 2480 v2 -
Hi, have you tried to do a factory reset?
Hold SHIFT and press F4 (Utility). Press PAGE to get to page 3. Press F6 (PrmIni). Press F5. Press ENTER/YES.
If the factory reset does not fix the problem i think you have to format the disk because it has a fragmented disk .......
