SOURCE: where can I purchase a wrench to adjust the
Purchase at any hardware or home improvement store (ACE, True Value, Lowe's Home Depot etc)
Testimonial: "I'll try it thanks"
SOURCE: husqvarna chain saw rancher 55
Try this get back to us with the results.
Ignition Coil Test
http://www.youtube.com/watch?v=L7WNBDRG4C4&feature=PlayList&p=3789DC1EE87C8098&playnext=1&playnext_from=PL&index=21
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
SOURCE: how to adjust the carburator
Unfortunatly there are special tools required to adjust the screws, the screws are set from the factory for the best emmisions. The screws are anti tamper with splines rather than a screw driver slot, before making any adjustments check fuel filters and hoses first, it is not good to try and compensate for fuel blockages by richening the carb, max rpm must be set up useing a engine tahco and should not exceed 12500
