SOURCE: AV1 / AV2 Connections don't work
No picture or dark picture
Check R516 (56Kohms, 0.5w) or R517 (27Kohms, 0.25w) for high
Will not come out of standby, no picture
If at power on voltage on pin 37 of the micro drops low then reverts to 5v suspect memory chip ICA07 (Toshiba 23319016)
No picture No sound
Faulty IC TDA6107q on crt board
No picture on e-e, I.F output ok
This was due to switching chip IC3901 (M51292FP) on the scart panel
SOURCE: my sharp tv model 20H-S60 remote input button is not functioning.
Go to www.remotes.com and they will tell you in most cases how to revive your old remote! or order an orignal (which you may have to do to change the function!) tv remote for your model!
SOURCE: Input Problem
Mine was the same, except i also could not access HD Components.
Unfortunately i had to get some one in, as the circuit board at the back of the tv was burnt out.You might have to get a technician in to service and replace the burnt circuit board.
SOURCE: Emprex HD 3202 control panel not operating
My first thought then is that the main board may have capacitor damage that will affect the boards ability to "understand" the control signals, if you can I would have the tv looked at at a service center for damaged boards and components, might be an easy fix but might not be (new boards), The lcd panel is good that can net you several hundred dollars at a min.
peope break them all the time and a simple change out is worth several hundred dollars, vs a new tv
SOURCE: I have a Sony KDL-32V4000 TV. I have a Sony
Press Info/ Display button on TV remote, on-screen display will disappear.
Testimonial: "Many thanks for rapid response - It Works! Question is why Sony don't put this in the Manual!"
