Why would you want to put gas in where the oil goes?.. oil goes where the oil goes, fuel goes where the fuel goes! Pre-mix your 2stroke oil in a Jerry can along with fuel then tip it in where the fuel goes, where the oil goes is where the engine oil goes (not the 2t oil) 2sroke pre-mix lubricated the big end bearings in the crank case and has nothing to do with the engine oil
If you mean where the chain oil lube goes then you could have a fire if any sparks occure ! If its where a seperate 2stroke oil feed should be then you will not lubricate the engine internals and sieze the engine ! Just drain out and fill with oil , 2stroke will need to be bled on the side of oil pump !
