MTX Thunder 8000 T8154A Car Subwoofer Logo
Posted on Nov 07, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No sound im not getting any sound from this woofer
Anonymous
Level 2:
  • Expert 109 Answers
  • Posted on Jul 17, 2008
Anonymous
Expert
Level 2:
Answers
109
Questions
0
Helped
69658
Points
170
Can you physically move the cone or is it siezed? hook up a wire to its + and - and then do a pop test using a 9volt battery + to + and - to - on the battery if it doesn't make a sound then the woofer is blown, if it does pop then the problem lies within your amp.
Anonymous
Level 2:
  • Expert 185 Answers
  • Posted on Apr 10, 2008
Anonymous
Expert
Level 2:
Answers
185
Questions
Helped
62591
Points
236
Well see if the amp is even working first if not that then try a diffenrt channlel and then after all that then maybe its the sub
Anonymous
Level 3:
  • Master 752 Answers
  • Posted on Nov 07, 2007
Anonymous
Master
Level 3:
Answers
752
Questions
0
Helped
393122
Points
1932
Use an Ohm meter to test the voice coil. If you don't have one, any car audio shop or repair shop will likely do it for free.
Anonymous
Level 3:
Master:
  • Master 505 Answers
  • Posted on Jul 18, 2008
Anonymous
Master
Level 3:
Master:
Answers
505
Questions
0
Helped
157959
Points
1168
See if the amp is working correctly
Problem with receiver electronics
Ok, im not sure what your asking
please rephrase question.
Very little output from tweeters Samson Resolv A6
same issue here, my 6 inch woofer is good but the tweeter is not producing sound, i opened the box myself, theres not signal going to my tweeter, how can i check to see if its a wiring or other issues to diagnose myself? heres some pics
JL Stealthbox 10w3 Subwoofer just shut off no sign of problems just quit working im not stressing it out by operating it above its limits its being powered by a JL HD900/5 AMP im concerned it might be...
If this woofer is a dual voice coil woofer and if you are running your amp bridged or in mono would suggest try wiring your woofer in series.But before Idid anything I would unhook the woofer from the amp and pop it with a battery to make sure your woofer is still connected.
HELPP!! How to connect ''bush dvdav11k'',to TV without DVD Player
HI,
I TOO HAVE BOUGHT THE AV11K. I TOTALLY HATE IT. ITS LIKE ITS BEEN CO-DESIGNED BY THE EUROPEAN SPACE AGENCY AND THE PLAYER AND WOOFER/AMP DONT FIT TOGETHER.
ID LIKE TO SAY THIS THING IS SO POORLY DESIGNED IT REALLY WOULD BE WORTH SENDING IT BACK FOR A REFUND.
ON THE BACK OF THE PLAYER, AND THE WOOFER YOU'LL FIND LETTERS. IE LF,LB,,,,RF, RB. (LEFT FRONT , LEFT BACK ECT). USING THE 'TULIP CABLES SUPPLIED YOU NEED TO CONNECT THE WOOFER AND THE PLAYER TOGETHER MAKING SURE THE LETTERS CORRESPOND.
DO THIS FOR ALL THE CONECTIONS ON BOTH THE PLAYER AND THE WOOFER. THERE SHOULD BE NON LEFT OVER.
THE LETTERS CORROSPOND THE THE POSSITION OF THE SPEAKER IN THE ROOM. SO ( I ADVISE YOU GET A REAL OF EXRTA SPEAKER CABLE FROM EBAY FOR A COUPLE OF POUNDS ) AND PLACE THE SPEAKERS IN ALL THE FOUR CORNERS OF THE ROOM THEN FILL IN THE NEEDED CABLE TO MAKE IT REACH THE WOOFER, WHICH MOST LIKELY YOU WILL HAVE BESIDE OR BEHIND THE TV AS ITS MOST CONVENIENT THERE ( WOOFERS ARE BASS MAKING SPEAKERS AND DONT REALLY CARE WHERE THEY ARE PLACED IN A ROOM.)
YOU SHOULD BE READY TO GO NOW.
THAT IS IS YOU CAN GET ANY SOUND TO COME OUT THE SURROUND SOUND SYSTEM ( LIKE I COULDNT).
THE SMALLER REMOTE IS FOR THE SOUND. THIS CAN BALANCE LEFT AND RIGHT AND VOLUME. AS WELL AS SELECT A AUX INPUT SUCH AS AN IPOD ECT. ( FOR THIS YOU WILL NEED A SIMPLE 3.5 > STEREO PHONO PLUGS. SIMILAR TO THE ONES USED BY THE AV11K.)
WHY IN HELLS NAME THIS SYSTEM IS ON THE MARKET I DONT KNOW. GOD PLEASE RE-ANIMATE MY LAST, AND TRUSTY PHILIPS DVD PLAYER..
HOPE THIS HELPS ALL UNFORTUNATE AV11K BUYS.
YOURS SINCERELY,
ALEX
1helpful
Problem with woofer....my edifeier woofer is not in aucuastic mod
Edifier works best in ausctic mode only when played in 5.1 surround mode....does you system hav a sound card ? if not then go for it..im sure it will work as these are THX certified speakers
Goodluck :)
2answers
How do i get to auxillary..trying to hook up amp and not getting full sound from sub woofers...what need to be done?
what r u doing why do that u need to be in aux. what do u meane by not getting full sound out of subs
Lanzar MAXP84 subwoofers problem
Unplug your subwoofer speaker cables and then turn the vehicle back on, and if the protector light turns off it is your woofers.
If it is still on, it could be a bad fuse going to your battery, a bad fuse on the amp, or a bad amp. :)
Top MTX Car Audio & Video Experts
Jose Ramirez
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
