SOURCE: can the jabra bt350v sync to an iphone?
if the iphone have posibility for bluethooth yes otherwise no
SOURCE: where can I get just the manual for the Jabra
TRY CONTACTING JABRA CUSTOMER SUPPORT AT
http://www.jabra.com/sites/jabra/na-us/pages/ccocontact.aspx
SOURCE: I need an owners manual for jabra model BT4051
You don't need one. After charging set, press and hold for several seconds until unit blinks repeatedly. Now it's on.
To turn it off, repeat procedure.
Press briefly to take incoming calls, or to place calls if your phone is voice activated. You should hear a beep after each press.
Use + and - buttons to increase/decrease volume.
Unit blinks once, intermittently, when it's ON. That is normal operation.
Note: It takes a few seconds for the connection to occur, after you initiate a call or take a call, and other sounds alert you when the connection is taking place. You'll learn as you go.
SOURCE: pairing my blackberry pearl to jabra bt4051
Go to this site, and it will walk you through each step to connect your
particular Jabra headset with your cellphone. Choose the headset, and
then at the next page, choose your phone. Moving your mouse over each
step will change the picture to what you should be seeing on your phone
at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
