DEPTH ALARM An alarm on a divers' watch that sounds when the wearer exceeds a pre-set depth. DEPTH METER or DEPTH SENSOR A device on a divers' watch that determines the wearer's depth by measuring water pressure. It shows the depth either by analog hands and a scale on the watch face or through a digital display. DECK WATCH A large-sized ship's chronometer. DEVIATION A progressive natural change of a watch's rate with respect to objective time. In case of a watch's faster rate, the deviation is defined positive, in the opposite case negative. DIAL Face of a watch, on which time and further functions are displayed by markers, hands, discs or through windows. Normally it is made of a brass - sometimes silver or gold. DIGITAL WATCH Said of watches whose indications are displayed mostly inside an aperture or window on the dial. DIVERS' WATCH A watch that is water resistant to 200M. Has a unidirectional rotating bezel and a screw-on crown and back. Has a metal or rubber strap (not leather). May have a sapphire crystal and possibly, a wet-suit extension.
click on mode or setting option.then you will see the default time.edit it..try to change it using select or any mode available.there you can see 24hr clock and 12 hr clock.select which one you want.if it is in 12 hr then the time will be displaying like eg:7:00am or 7:00pm it means that it is in twelve hours.if it is showing 7:00 or 19:00 it means it is in 24hr clock.
When the amount of available memory in flash memorybecomes low,
"FILE" flashes in the lower left corner ofthe display in all of the submodes
of the standard mode as well as in the dive mode. Thewatch
automatically switches to the flash memory statusdisplay of the system
monitor mode when the water sensor gets wet while thiswarning function
is activated. Please note that although it is possibleto use the watch for
diving in this state, log data may not be recorded inflash memory during
diving.
The file error warning function is also activated andadditional log data is not recorded if the
duration of a single dive exceeds 2 hours or if morethan 15 dives are made in a single day. The
file error warning function may also be activated whenthe water temperature during diving is low.
It may not be possible to receive watchsettings by data communication while the file error warning
When the watch has switched to the file error warningdisplay, perform the garbage collection
procedure in the system monitor mode of the standardmode. Thedisplay returns to normal
following completion of garbagecollection.
Garbage collection begins when button (C) is pressedfor at least 2 seconds during the
flash memory status display.
• During the garbage collection operation, an alarmsounds and "G.C." is displayed on the
display. When garbage collection is completed,"Done" is displayed on the display.
• Garbage collection cannot be performed when"G.C." has changed to "NG" on the
battery charge indicator or when the water sensor hasbeen activated. "Fail" is displayed
on the disPress button (B) in the system monitor modeof the
standard mode to switch the watch to the Flash Memory
Status Display.
Formatting Flash Memory
Formatting of flash memory begins when button (B) is
pressed while pressing button (C) simultaneously forat
least 2 seconds.play at this time.
[email protected]
The problems is very simple: On the back cover (inside) is a little Cu metal Part. This part is glued to back cover using a poor glue (rubbered glue) and, in time, is moving from original position. You must put back this parts to original positin ( a little hole inside of back cover) and glue using a good glue. When the back cover is mounted , this part must have a ferm contact with two springs from mechanism (sensor for back cover open).
If beatwin this springs isn't a electric short (using Cu metal parts) the internal mechanism of watch "see" the back cover is open and show "OPEN" on screen!
