Question about Janome Sewing Machines
How do you oil a model 8077 Janome sewing machine?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Consult manual if you don't have one search the internet with your sewing machine model number...Example...name Model number and free download.
Posted on Aug 29, 2014
SOURCE:
hazelgrace
  • 340 Answers
SOURCE: How do i thread a
Hi
I couldn't find a manual on the Janome site for the machine you have but I did find this one for a similar looking machine. It should be enough to get your started on how to thread your machine and what the different parts are for.
http://www.janome.com/documents/File/ManualFile/Sewist509.pdf
Posted on Sep 04, 2010
lavon82931
  • 17 Answers
SOURCE: owners manual for sewing machine Janome JF1004
Try this web site for sewing machine manuals http://sewing.about.com/od/beginner1/ig/Sewing-Tools/Sewing-Machine-Manuals.htm
Posted on Jan 25, 2009
SOURCE: Download a Janome (Jem 639) sewing machine manual
Just today  i got out my little janome i bought years ago and it is this model.  There was no "manual" with the machine.  All that came with it is a large 20X14 two sided print out.  I can scan and send this to you with an email address.
Posted on Mar 02, 2009
SOURCE: machine will not complete a buttonhole, keeps showing error code 6L. No error code listed in manual. Machine will only do first half of buttonhole and then shows code and stops.
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
Posted on May 27, 2009
SOURCE: How to thread sewing machine Janome model 372
how to thread a janome model 372
Posted on Dec 27, 2009
Oil my machine
This really depends on the model of machine you have. Most new machines are self oiling, but some still require a drop of oil in the bobbin case. Your sewing machine manual should include a oiling diagram if your machine requires that the user oil their machine. You should be able to download a manual for your machine from the Janome website, even the retired models are there.
Chris
Mar 28, 2014 | Janome Sewing Machines
What does error code E1 mean on the janome machine 8077
Google make model and error code perhaps you will find what you need
Feb 10, 2013 | Sewing Machines
Bobbin thread is jammin up after about 3 rotations of wheel on my janome 8077 - is this a timing problem?
try changing the needle
make sure the thread has not come off the thread take up lever
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not over filled
make sure the bobbin is not damaged
it's very possible that the machine could be slightly out of time
Sep 01, 2012 | Janome Sewing Machines
Janome 8077 instructions
check with Janome customer service about a manual
Mar 10, 2012 | Sewing Machines
The needle and thread get stuck at the bobbin and the lo light come on my 8077
Turn the power off and replace the needle with a new one, making sure the install is as described in the manual for your machine - on most newer models, this is with the flat side of the needle shank facing the back of the machine.
Before turning the power back on, raise the needle to it's highest position. Remove the face plate, bobbin and bobbin case. Clean the area in and around the shuttle from lint and/or threads that may be tangled there.
May 15, 2010 | Janome 8080 Computerized Sewing Machine
Where drop oil
Open the PDF for this model (Janome mechanical) and see if it is the same - http://janome.com/index.cfm/Machines/Sewing-Quilting/TB12
If not, contact Janome for a manual.
Apr 20, 2010 | Janome 2049LX Mechanical Sewing Machine
Sewing Machines Logo
192 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
