Hi ,
You need to use the install cd that came with your unit but probably it won't run beyond XP . Starting from Windows 7 ,
the only work around possible is to install a virtual version of Windows XP on your drive : http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
Wish you good luck , otherwise you will need to purchase a compatible unit .
Regards .
SOURCE: I need BENQ 5000 scanner driver model 6678-9VZ
hi there
is your scanner listed here BenQ United Kingdom - Downloads
althought you will need to select your country for them
riz.
SOURCE: Driver for Benq Scanner 5000
I found this for you. Your driver depending on operating system is about halfway down the page.
http://www.opendrivers.com/categorycompany/16/16907/scanner-benq-free-driver-download.html
Hope this helps.
