I WAS CLEANING MY BROTHER LS 1217, AND I HIT THE BOBBIN CASE LATCH SPRING AND NOW I CANT FIGURE OUT WHERE IT IS SUPPOSE TO GO.
SOURCE: Spring unattached on Brother LS-1217 near bobbin
Check out this site. There is pictures of each machine there. All the Q&A answers in simple language, as
well as a GREAT cust. support. (its a Brother after all!)
I found download manuals there as well.
http://welcome.solutions.brother.com/bsc/public/Model_list.aspx?reg=us&c=us&lang=en&titleid=36
I hope this helps! Thanks for keeping the Art of sewing going!!!!
Happy sewing!
SOURCE: bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
SOURCE: can't draw up the bobbin thread
Make sure you have enough of a "tail" from teh bobbin... Probably 4 inches or so before starting. If that doesn't work, check upper tension and needle is properly seated.
The needle drags the thread down and then starts back up causing a loop at the eye which a shuttle goes through and acrries the upper thread over the bobbin. The upper thread then drags the bobbing thread up.
SOURCE: I'm new to sewing. I was given a Brother LS-1217
Page 15 in this users guide.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1217_EN_186.PDF
SOURCE: where can i find a free manual for the ls brother 1217?
Hi! I found your manual on Brother's web site: http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=LS1217
Good sewing!
