Nor-Lake Master
- Posted on Jun 28, 2009
Re: Out of nowhere, my Nor-Lake walkin cooler has begun...
U are going to need to have the thermostat tested, I think u will find it has failed. try this turn the control down to minimum setting, does the compressor stop running? if not then replace the thermostat.
the serial # is 06030526
mod/job # is KL7468-CR-M-58716
Con-temp
size KL26X78 60 cycles
volts 120 1.5 Amps
Phase 1 179.4 watts
I sent the information regarding the product # that you asked for. Did you receive it?
My Nor-Lake walkin cooler is running too cold. I have had it for three years and have never adjusted the thermostat until the problem began. When I went to the restaurant, I found that my produce was frozen, so I turned the thermostat up, but it is not helping. Today it was running at 19 degrees when the thermostat says 50 degrees.
here is the product info
serial # 06030526
mod/job # KL7468-CR-M-58716
Con/temp
size KL26x78 60 cycles
volts 120 1.5 amps
phase 1 179.4 watts
