There are many things to be remembered while doing the maintenance of the Honda livo bike. Here I have mentioned some of the steps, have a look
=> Engine oil centrifugal filter clearance.
=> Engine idle speed adjustment.
=> Fuel line inspection for any leakage.
=> Fuel strainer screen cleaning.
=> Inspection of throttle free play & lubrication.
=> Inspection of choke operation, spark plug.
=> Valve clearance and adjustment.
=> Cleaning and crank-casing breather.
=> Inspection of brake fluid, top-up if required.
=> Checking and adjusting brake free play.
=> Inspection of brake shoes/pads wear, replacing it if required.
=> Inspection of clutch cable operation, adjusting free play if required.
=> Checking battery voltage.
=> Checking free rotation of wheels and correct tyre pressure.
These are some important thing you should remembered and for detailed service check out for the service manual of
Honda livo.
