Per page printing it is taking at least more then 30 min so what is exactly issue.
SOURCE: C6180 printing slow
This could be from the image you are printing. If you are printing from a computer or memory card, the dpi (dots per inch) may be higher than some.Standard printing is typically 400dpi, and you can change the settings on your computer or the printer directly. Memory cards and some photos from your computer may be 600dpi and will likely take much longer to print since there is more "color information" that it is trying to fill.
Let me know if this helps.
SOURCE: I have HP 4355 all in one printer .Whe I click on
there exist two printer drivers, one for printer and another for fax... may be your machine have the print to fax driver as default hence it takes you to fax page... u can manually select (or make default..) the printer driver to print document on paper... if it does not exist try reinstalling it.............
SOURCE: HP Laserjet 1200 prints pdf documents slow
pdf documents are historically slow, they usually depend on how they are created and how many attachments or upgrades have been added to the document. this accounts for some of the variations of speed the documents are printed.
SOURCE: HP Officejet 7210 Is Very Very Slow (10 mins / page printing)
And I have exactly the same problem too that has happened in the last few weeks.
I've tried reinstalling the software/drivers and resetting the printer to factory settings but no joy. An upgrade either windows or HP must have caused this!
