SOURCE: How can i use sony dcr-sr68 use as webcam
HI,
I'm afraid, Sony DCR-SR68 can not be used as webcam because it has no option of video streaming and goes to standby mode if does not operate for few minutes to save power.
Thanks.
SOURCE: i am using sonu handicam dcr-sr68..and it is
Possible there are errrors in the memory. transfer the recorded files and then format the drive. If not connect to the PC after downloading the software and check for errors. If not there are errors in the drive.
SOURCE: What's your problem?
The most likely cause is a component failure in the power circuit. This can be repaired fairly inexpensively. However, it's not really a user serviceable problem and should be looked at by a qualified technician. Here is a link to a repair shop that should be able to help you.
www.discountcamerarepair.com
