Error Code P1345 is defined as Crankshaft Position-Camshaft Position Correlation.
This error code is a manufacturer-specific trouble code, meaning it does not apply to all vehicles makes. Rather, it applies only to specific vehicle makes, such as Audi, GM (Chevrolet/GMC), Isuzu, Lexus, Mazda, Toyota, and Volkswagen. Specification of the definition, troubleshooting, and repairs still vary from one make and model to another. Regardless of how the manufacturer describes the code, all vehicles will have one thing in common with this code - it's an ignition problem.
SOURCE: running dtc p1345
You may have the distributer a tooth off and the computer can not calibrate the timing properly. Set the engine at (top-dead center) at the crank harmonic balancer and remove dist-cap to see if the "DTC" is off. If so, when distributer is out, you will have to use a longer flat head screw driver to reach down in the intake and turn the oil pump shaft to advance it for the re-installation of the distributer as it will turn when threading into the cam gear. Hope this helps.
post to cars not computers or learn to google or read your service manual.
P1 is a factory code, P0 is standard fed codes USA.
P1 varies by every maker of car, made. NONE TOLD.
surely you know name of car, and also DRIVE line in the car matters most and year.
engine size and what transmission.
learn to post in cars, not computers.
https://www.fixya.com/cars/troubleshoot
no car told no joy and for P1 codes, you will get 10x wrong answers. lacking the cars driveline.
the chevy code and BMW code same are NOT The same, I can do this 100 more times, not the same.
