Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
SOURCE: freezer drain freezes, and constant clicking noise
This clicking noise is a bad relay.
Get it serviced before you run in to a real problem
SOURCE: top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
SOURCE: Whirlpool upright freezer turning itself off
hi,my name is sourine,i have a probrem with my freezer not cool at all,it's about20 year old.
BRAND WHIRLPOOL
model EV150N A O
14.6 c.f
SOURCE: whirlpool upright freezer evl209nbtq making noise
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
SOURCE: I have a Whirlpool Model EV 200N Upright Freezer
If there is frost forming at the bottom to the door, your door gasket is leaking at that location. You may be able to relax gasket back in place with hair dryer, be carefull you can melt gasket. If it is sheets of ice, your defrost drain may be frozen
