Question about Goldstar DH504EL Dehumidifier
Owner manual for goldstar dehumidifier - Goldstar DH504EL Dehumidifier
4 Suggested Answers
SOURCE:
  • 5 Answers
SOURCE: NO POWER TO MY DEHUMIDIFIER
I took my dehumidifier apart and I found why the unit no longer would start.
First, there is a fuse inside the metal compartment that houses the control circuit board.
However, the fuse was not blown. Instead I found the relay that controls the compressor,
(circuit diagram calls it RY-COMP) was not functioning and was left in the open position.
The relay must switch the compressor on/off based on humidity, full water hopper, and
maybe other factors like temperature.
The RY-COMP is a large black plastic component on the circuit board with two
wires (blue and black) connected at the top. I tested the contacts and they remained
open when starting up the dehumidifier. Doing a small bit of rewiring so that the blue and black wire
were connected and also wired to RY-COMP terminal 3, the dehumidifier came back to life.
However, this is good for proving what broke but without an electronic control to cycle the
unit on and off and to halt when the water hopper is full it's not a valuable alternative and
it risks a burnout of the compressor from constant use.
I think the RY-COMP relay is a solid state relay which could have gone bad from a spike
in voltage when plugging the unit in or cycling on/off.
I certainly don't want to buy another unit where the circuitry is not robust enough to survive
plugging in every couple weeks. I was thinking I could try replacing the relay with a magnet relay which would probably survive spikes much better.
Posted on Sep 13, 2008
  • 4 Answers
SOURCE: Goldstar DH304 Dehumidifier
Take cover off. First check the fuse on the circuit board. If it's blown replace it. That should get the motor running, the motor might be or is going out. If the motor is bad you'll have to replace the motor. If the fuse is good and the motor is good, unhook the wires on circuit board that go to the humidity control switch. If the unit comes on with the humidity control switch unhooked, you'll have to replace the humidity control switch. Sears has them for about $11.50. Hope this helps.
Posted on Jul 11, 2009
SOURCE: goldstar dehumidifier dh305t7
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=DH504ELY6&matchedModelCode=NOT_MATCHED&searchEngineModelCode=DH504ELY6&initialTab=documents&targetPage=support-product-profile#
Only available for DjVu reader (download link on LG site). You'll need to download and install the plugin then close and relaunch your browser. I was only able to get it to work in IE in the end with Firefox and Chrome not working. IE objected I had to "allow" the plugin to run then once again close and relaunch the browser then it finally worked. Good Luck!
Posted on Apr 01, 2011
Where's the filter located?
If you know the model number, you might be able to find the manual here... http://www.manualslib.com/brand/goldstar/dehumidifier.html
Jun 24, 2014 | Goldstar Dehumidifiers
Tip
Url for owners manual
This dehumidifier is made by Goldstar (LG Electronics) which is found by looking at the first three numbers of the model number "580" and finding the cross reference list of actual manufacturers. The Goldstar model number for the same unit is "Model : LD50EL". This is the pdf file obtained from their site. Below is the url for the owners manual. or go to their main website at: http://us.lge.com/ http://us.lge.com/download/product/file/1000001991/LD40E_LD50EL_LD65EL_LD50EBL.pdf Sorry this is all I have. I tried to upload the 5mb manual, but got a timeout error. So, you will have to download it yourself at the above location.
on Jul 31, 2007 | Kenmore 54501 Dehumidifier
Do i need a filter to run a goldstar dehumidifier DH504ELY7? Don't have manual
No,
If the coils start to plug up just wash them down or vacuum them off....
heatman101
May 28, 2010 | LG DH504E GoldStar Dehumidifier
Does not collect water and shuts off after couple mins.
Your sealed sysyem has a leak and the unit is low on freon causing the compressor to overheat. Check your owners manual many Goldstars have a five year warranty on the sealed system. If so you need an LG dealer to exchange it for you. They will submit the work order and LG will issue a CO number for you and contact you.
Jan 15, 2010 | Goldstar DH504EL Dehumidifier
Goldstar Dehumidifier compressor short cycling...
If the coil is freezing up and the compressor is short cycling,there must be a low pressure switch opening, do to either, low on charge or not enough air across the coil.
Jul 05, 2009 | Dehumidifiers
Gold Star HD504EL Dehumidifier owner's manual
Try going to the manufacturer's web site. Hook into Support , or Downloads. Then look for the operating manuaal. Or, in their site, Search for the manual. This often works.
Sep 27, 2008 | Goldstar DH504EL Dehumidifier
Goldstar dehumidifier dh305t7
The PDF file of the owners manual (35 pages, in more than one language) is over 8000 kb. This site seems to limit posts to 150 kb. It does not show an exploded parts diagram either. The manufacturer likes to use djvu files which download faster, but are not supported by "Fixya". I don't know what parts you are calling the interior panel connectors. Although we cannot ask for email addresses, I've seen some people post some.,....
Possiblly try: http://www.goldstarappliances.com
Sep 13, 2008 | Goldstar DH504EL Dehumidifier
The hose connector does not drain the bucket, it drains the condensate before it enters the bucket. Tube passes through back of dehumidifier by the cord wrap area. (you may have to remove a small cover)
Aug 25, 2008 | Goldstar DH504EL Dehumidifier
Connecting drain hose to the Dehumidifier
If you go to this site you can download the owners manual. Follow the instructions and it should solve your problem.
http://136.166.4.200/contents/Dehumidifiers/DH30.htm
Sgt 48
Oct 20, 2007 | LG DH30 GoldStar Dehumidifier
Goldstar DH504EL Dehumidifier Logo
163 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Paul
Paul
Michael Youngman
Michael Youngman
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
