Your dishwasher may have a filter located near the bottom or under the lower spray arm. This filter should be inspected and cleaned regularly. Follow your dishwasher owner's manual for specific instructions about how to properly remove and clean this filter, if equipped. If there are any holes or other damage to the filter, you'll need to replace it immediately to protect the dishwasher's pump and motor seals from damage.
Hi
OE in your LG dishwasher is a drain error and dishwasher not draining issue usually occurs due to
kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for
any visible clogging, remove if present. If no visible lint is present then
remove then turn off the dishwasher and remove the drain hose and check for any
visible clogging. If it's still not visible then the drain filter or drain pump
is clogged and you'll need to clean the drain filter and drain pump. Also,
check for any food pieces stuck near the pump impeller. Hope this helps... Please post back for any further
assistance.
Daniel
