Tv will not turn on, blinks 10 times. how do i fix this
SOURCE: my panasonic th-50pz800u won't power
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
SOURCE: TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
SOURCE: Panasonic TH-42PZ77U HD Plasma tv has 10 blinking lights
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
