SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
SOURCE: Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
SOURCE: LTX 1000 CRAFTSMAN /42 IN. DECK BELT LODGED ABOVE
Without the model number, I couldn't tell you what belt goes on the ground drive. That 174883 is a 5/8 x 97" and is your deck drive belt. Your ground drive belt may just need replacing. They will wear thin and loosen up between the pulleys and cause the problems you're having. The old belt may still have the numbers on it.
SOURCE: need a diagram for a sears craftsman 42 inch deck drive belt and
I don't have a deck diagram but you should be able to figure it out it you put the back part of the belt (flat) up against the pulleys that are wide and the narrow part (v) into the smaller pulleys. It might take a couple of times but it is not that hard to figure out. Also put the (flat) side of the belt on any tension idlers. Hope this works.
