Kimberly,
It is possible that there is an electronic selenoid valve on the bottom of the fuel bowl. If you are not familiar with what a fuel bowl is, follow the fuel line from the fuel tank to the carbeurator. On the bottom of the carbeurator is a bowl shaped cup. That is where fuel is stored and the level is maintained by a float.
On some lawn mowers as mine on the bottom of the bowl is a device (selenoid valve) with two wires going to it. When the engine is running it is energized to allow fuel to enter the fuel bowl. When the engine is turned off it de-energizes shutting the fuel off to the fuel bowl.
I had the same problem with mine - be careful though, don't start the engine if it's full of fuel - you could damage the piston.
An easy fix is to go to an auto parts store and get a fuel cut off valve and install it in the fuel line. That's what I did. You have to remember to open it when you run the lawnmower and close it when you are finished.
However, you can call a local lawnmower repair shop and they should have the part in stock. Make sure you give them the make, model and serial number of the lawn mower. Also include the same information from the engine - more infor is better. Hope this helps.
SteveKJR
If the gas is filling up the cylinder oil level should be rising also - depends on how long it takes to leak into cylinder - bowl of carb should have a fuel cut off that might be stuck open and carb float must be leaking by also
