RTO Pelouze Scale With Remote Display - 400-Lb/180 kg Capacity Logo
A
Anonymous Posted on Jul 03, 2014
How do you calibrate Pelouze scale model 4040?
1 Related Answer
Anonymous
  • Posted on Aug 26, 2010
SOURCE: how to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
1helpful
2answers
Can I buy current updated dial only showing new postal rates? Where can I order it?
The Pelouze K-5 is a discontinued item. The slim chance of getting an updated replacement dial would be if you found such available for a similar item and tapped that items replacement dial. As the original dial was replaceable, its manual should offer instructions on how to manually change it. Office Supply might have a similar dial but as the scale is discontinued, your chances of finding a Pelouze part with updated postal rates probably are less than zero. I don't think querying the company will help in this instance unless you just want to buy another model of postal scale.
Fix my pelouze fs6 scale
Based on its appearance I'm guessing that you need to unplug it and open it up. Clean it as well as you can with a stiff brush and an electronics safe cleaner. Roaches are the most likely cause of your scales failure!
All the above may be fruitless, it may not be possible or worth the cost to repair.
Time for a new scale! You must keep it clean and turn it off and disconnect it when you aren't using it. Roaches like warm damp dirty places!
I need user manual for the Pelouze Model PE5 postal scale capacity 5 lbs?
If i were you i would try to search for it on google or look on their website.
13helpful
2answers
When powered up the display reads 4040 and will not display anything else. buttons don't seem to function
We solved this hold down the lb/kg button and the zero/hold and the on button at the same time up comes a A-of and then do it again and it will come up CAL wait a momment and then turn off and it will go back to zero.
23helpful
4answers
How to calibrate a Pelouze model 4010 scale with a
1helpful
I need to download the new postal rate on the scale, but I have no user manual or connector. Please let me know how to go about doing this.
Here is the answer on the Pelouze web-site you can also download a manual here. They have all of the software you need to get the rate change installed.
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=650
PELOUZE 4010 SCALE READOUT FAILED
my pelouse when i turn it on it stays on 0.0 when i put weight on it stays on 0.0 it then goes of i need help to get it to work
Top RTO Health & Beauty Experts
Rob Hill
Rob Hill
Thomas Perkins
Thomas Perkins
Harsal Patel
Harsal Patel
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
