SOURCE: Zebra printer problem
chek on setings if the sennsor is reflective, transmissive or auto.
should be on Auto. try to read the Sensor profile, and check if read the gap.
Try the Manual calibration, and then run the sensor profile.
tur off and on again.
SOURCE: My Zebra Zm 400 keeps saying Pause Error Condition
make sure that the maximum lenght for the label is set to something greater than the physical length of the label. I was having this issue with a 4x3 label. As soon as I increased the maximum lenght to 5 inches it worked.
SOURCE: my zebra printer wont line
run the sensor profile, check if check the gap, run manual calibration, if ask for reload media, please take 3 or 4 labels from the label rolar, put through the sensors (check if ribbon(if use) is install on the correct spots and don't stop the sensors to read the gaps) and run the manual calibration.
SOURCE: my printer says error condition paper out. But it
try to recalibrate media and sensors, run calibration, and run sensor profile, save, and restar again the printer. check if setings from the driver are correct or they can change the setings from the printer
