SOURCE: Image looks with white verital striped lines in playback mode
Mine had the same problem (except the stripes are horizontal). I sent it to Canon and sure enough it is the CCD problem that many of these have. The good news is that it is covered under a recall and Canon will fix it free, including the shipping.
SOURCE: My canon a470 produces a blury image after taking the shot.
hi,
you must have a lance problem,so please contact any authorised person for repairs , its may be a lance flap is cracked,
SOURCE: White photos canon A470? i have a canon
I had this problem too, I think it's the shutter problem, it doesn't close
when a picture is taken, therefore, causing the over exposed photo...I've sent it back to canon, still waiting for the reply...
Kevin - Malaysia
SOURCE: I have my canon a470 digital camera, recently i
This sounds like a stuck shutter, with the shutter stuck open. See this link, trying Fix #5A. If Fix 5A does not work, your camera is then likely experiencing a broken ribbon cable to the shutter control. Unfortunately, repairing that cable would be more costly than the value of the camera. Also, repairing the cable yourself is not recommended as finding a replacement cable would be just as costly, and the actual repair is very difficult.
SOURCE: canon powershot A470 problem when
The shutter flex cable inside the lens is broken. Happens to all cameras from Canon A4xx series. At day the images will be overexposed with horizontal lines on it, but it could look better at dark / night. The FLEX has to be replaced. Canon doesn't supply new flex cables for these, but there are some cheap copies on ebay. But as these brake very often, I wouldn't suggest you investing money in this camera, because it will brake again sooner or later.
