My kyros tablet MID7047 Is not taking a charge at all. I have been using the micro usb port to "charge" but is the dc charge port the only way to charge it? I dont have that charger.
SOURCE: will not take charge
Sounds like your battery is knackered, only thing to do is replace it, you can check the battery with a voltage meter or take it back to the supplier and ask them to check it foryou.
I had the same problem with my vizio tablet. The port came loose after the wife and kids kept playing with it. The tablet would not charge anymore. What I had to do was open the tablet and check if the little pins that connect the Micro USB port were still soldered on the circuit board. Mine were broken off so I had to replace the whole port. I couldnt even find the OEM replacement part so I had to buy a Mico USB (style B) port off ebay and made it work.
SOURCE: Coby Kryos Android Tablet
Leave the tablet connected to the charger for 5-10 minutes even if doesn\'t work. Then take out the battery and try with master charger and (switch on the tablet) after that, check whether the previous charger is working again or not again. If it doesn\'t show charging sign, then you have to take it to service center to change the charger connector.
SOURCE: Both Charger Ports Wont Take Charges
i can suggest you get a Duracell wireless charger which you just place your tablet on and it charges?
