On a bizhub 165 it's a fault with the sucktion fan motor so check
to see if turning and replace if needed. If this does not fix print control board might need replacing.
The suction fan is the fan on the right door. Try to rotate it with our hand, to see if it is easily rotating and try to check its operation while the copier is working. ------------------------------------------------------------------- Konica Minolta Error Codes & Solutions -http://www.kmcodes.com Drum, Transfer Belt and Fusing Unit Firmware Reset -http://www.bizhubreset.com Drum and Toner Chip Reset -http://www.chipreset.eu Transfer Belt and Fusing Unit Reset Kit -http://www.resetkit.eu
SOURCE: konica minolta bizhub 350 error code c5352
Cooling Fan fault. To clear open and closer the front door.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
SOURCE: ERROR C0910 KONICA MINOLTA BIZHUB DI 2010
2nd Drawer Lift-Up Motor Failure - The Lift-Up Sensor is not unblocked even after the set period of time has elapsed after the paper liftup operation for the drawer has begun.
Reset your Toners and Imaging units for Bizhub and CF series.
SOURCE: kONICA MINOLTA BIZHUB 750 SHOWING C3803 ERROR
You have a problem with the fusing unit. This is the assembly that gets hot and "fuses" the toner onto your paper. This error code means that the fusing unit did not warm up properly. You will need to have a service company come out to diagnose and repair the problem then reset this code as service mode entry is required in order to reset. It could be as simple as cleaning the thermistor, replacing the thermistor, thermal fuse etc. I would estimate the cost at around $200.00.
Here is the section from the service manual that deals with this code:
Thermistor /1 (TH1) detects a low
temperature when a specified
period of time elapses after the
fusing heater lamp is turned ON
for the fusing ON control.
SOURCE: how to fix error c-1183
This code is for a bin/tray raising or lowering failure in the finisher. This can be caused by either the trays not being fully inserted into the finisher or something stropped the bins from raising or lowering. Check the trays and make sure they are as close to the finisher/fully installed as possible. Then turn off then back on the main power switch (NOT the stand by one on the control panel)
You should see the bins raising and lowering into their home position.
