Polaroid FLM-3734B 37 in. LCD HDTV Logo
A
Anonymous Posted on Jul 03, 2014
Just put in new power supply board .was working maybe 10 minutes and it went out. Power supply does turn on and off with remote. What could be the problem?
Ray S.
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 03, 2014
Ray S.
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
582
Points
Possible inverter board bad or bad main board.
disconnect inverter board and see if set comes on..if it does then inverter board is bad..if it does not then suspect main board.
5 Related Answers
Anonymous
  • Posted on Feb 15, 2008
SOURCE: Black screen with sound
The TV lasted a little over a year & I'm glad I didn't get a warranty. A repairman estimate was $512 but he is still waiting for a control module replacement for other customers. They purchased the exteneded warranty but have been waiting over 6 months for parts that are still not in. I trusted the Polaroid name, my mistake to trust a name.
Anonymous
  • 362 Answers
  • Posted on Feb 25, 2008
SOURCE: Screen goes black with sound
the lcd control board is out side the control box, its probably the culprit, its under 20 dollars new. the swollen cap means that its getting too much voltage to that component. better do voltage checks on the power supply each transformer is labelled for voltage output make sure its providing the correct voltage and not surging, this can cause the tv to fail with serious problems. now mr zuzu13 you need to have the tv on a surge protector and be careful not to let it arc when plugging in. you also need to do the same checks as above its most likely a power supply problem causing the shut downs. also reset your tv to factory settings by punching in 8282 on the remote this might also solve your problems. but dont forget to check the power supply now it might save you a costly repair.
rhozel2010
romy sibug
  • 269 Answers
  • Posted on Aug 28, 2009
SOURCE: Missing Power supply and remote
Hi! i hope this would help, most power supply for 20 inches lcd are rated 12volts dc at least 5ampere. try replacing your power supply.
rulds2008
Grand Canyon Tech
  • 3867 Answers
  • Posted on Sep 22, 2009
SOURCE: Polaroid 4011-tlxb. Power to tv and it was turning
if you replaced the supply board then there is issues with the decoder board as you would need to chec kthat and see if its not the issue.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Anonymous
  • 5138 Answers
  • Posted on Dec 07, 2009
SOURCE: Polaroid flm-3701. Power supply is putting out 5
Look on power supply board for Bad capacitor 2200uf 25v or 1000uf 16v if it is puffed up on top it is Bad, also Main Board is the tuner board
Encompass Parts has some parts in stock for this TV and Free service Manual you can download online 1-800-638-3328 and for capaciotrs Call Mats 1-800-628-1118
I will turn my TV on, and it will work for anywhere from 10 minutes to 3 hours, then it will turn off. (The the picture and audio will go away) then within about 10 seconds it will turn back on... Then it...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
2answers
How to install power supply
get replacement first
turn off tower
remove all wires and connections
find case screws on back remove and put in a careful place
ground your hands with a strap to chassis
find power supply and trace power cables to board (2 or 3)
remove power cables
remove screws from power supply freeing from chassis
replace with new supply
plug in cables in same place as old one
close chassis
hook up wires to computer
count down from 10(just kidding)
maybe you get lucky
I went to turn on my Samsung a little bit ago, which was working earlier today, and now it won't turn on and is making a clicking noise. The noise does not stop until 10 seconds after I unplug it...
The tv power supply board it got short and already dead some how,tv have clicking noises mean ur tv power supply board are not stable and not regulating high voltages to the rest of the tv other boards.The tv power supply board that the board where the a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Samsung ps42a456p2 (42 inch plasma) won't power on, stays standby
i'm pretty sure the power supply board is dead. the most common problem with all samsungs.
10helpful
2answers
Viewsonic N3260W made loud pop and will not turn on.
We got the part in today and the hubby fixed the tv. It is as good as new. We are very happy with our $62 purchase.
Go to http://store.ramplus.com/fsfspopfrpos.html
FSP228-3F01, FSP Open Frame Power Supply Replacement for Viewsonic N3260W - 32" LCD TV
It worked like a charm and took about 10 minutes to put in new part and put tv back together.
Polaroid LCD tv - model TLX-04244 Shuts itself off...
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
If your TV is less then a year old, still under manufacturers warranty.
I service these power supplies, for more info write to [email protected]
While sitting wathcing my 50" Vizio plasma last nite and it started to flicker. Turned it off for less than a minute an the problem went away but came back within 10 minutes. Did the same thing again...
5helpful
2answers
TV's on. No Picture...No Sound
Have a problem with Zenith 37 HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound, TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how? Comment posted on Apr 22, 2009 I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire computer from scratch.
Actually, the TV belongs to my father and the problem that I stated was based on what he told me.
So the question is based on the symptom that I posted, how sure are you that the problem is the Power Supply Board?
Is it good to order PSB? Comment posted on Apr 23, 2009 Purchased 2 and half years ago. Expired one year warranty. Comment posted on Apr 23, 2009 Zohail,
This is LCD TV.
There is no problem with the wall socket nor current.
I put other appliances on same wall socket and worked.
It has to be internal problem.
As I mentioned on the main post, there was a 'pop' sound while watching and TV went dead.
Turn on remote control, there is blink green light and then green stays on, but no sound, no screen.
Turn off remote control, light turns red. Comment posted on May 14, 2009 I fixed the TV.
Orderd power supply board which cost me $136.51 total.
Replacing was simple.
Just removed the rear panel cover then electronic board housing cover.
Took power supply board with all the connector cables and replaced with new one.
Problem was a transformer connector which got burned and blow up the plastic cover.
But no problem with fuse and capacitors.
Thanks all for advises.
4answers
Won't power, light goes green 5-10 seconds later red flashing light is basically what's its doing. at 1st i'd power down the tv for a min and then it comes back up with no red flashing going on.
keep pressing the channel up/down button and the screen will come on it may take a few minutes dont use the switch on the side of tv just use the remote buttons u could try the power button on the remote aswell
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
