There is a SD memory card inserted in the camera
There are a couple of things you can try: first use a different memory card. The camera is not seeing the one you are putting in it. Also make sure the card is seated all the way in. It is spring loaded and will press down against a spring and lock in place. To remove it you press down and it will come back out as you lift your finger tip. If the card does not want to go in easily you probably have it turned over and are putting it is incorrectly. It only goes in one way.
SOURCE: Memory Card Error
Use USB card reader&writer to retrieve the pictures directly from the card.
SOURCE: sd card error on canon powershot s3
I get a memory card error everytime I insert a memory card. They are not locked and I have tried 4 different memory cards and nothing works. How can this problem be fixed?
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
SOURCE: Loaded new memory card, and screen reads memory
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
SOURCE: How to format an SD card on a Canon SD600 camera
Could be that you have the wrong memory card.
SD600 will only work with the old SD cards, but the SD780 will take the SDHC cards.
SDHC was intended to give 4gb or more of storage, while the old SD started as 16 mb. Different cameras have different limits, but it is always best to assume that the practical limit on an SD card is 2mb. Even if the SD780 will take the SDHC cards, it can be more practical to only carry 2GB SD cards and know that they will fit either camera
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
Note:
