Question about Just Wireless Bluetooth Headset Wireless Headset
How tp pair BT-38 - Just Wireless Bluetooth Headset Wireless Headset
I want to connect to BT broadband using my TP-Link TD-WD8901G routerg
Sounds like you need to change the TP link router for a wireless Access Point or a range extender.
Who knows what goofing around BT does with their equipment.
Mar 20, 2014 | TP-LINK TL-WR642G Router
Attach phone
hi there. first switch on the bluetooth of your phone . then switch on the on button of your bluetooth device and keep it pressed for few seconds till the time the power lightgets on and now in your phone go to the option search new device .once ur phone detects the bt 38 name get it paired and it will start working
Oct 29, 2013 | Just Wireless Bluetooth Headset - BT-38
Pair iPhone 4s with 2006 BMW x5
Key-in, Ignition On (but don't need to start the engine)Press the R/T button on the steering wheel. "Activate Phone" should display on the radio. On the iPhone search the BT device. Select your car and enter the passkey when prompt on the iphone. Make sure there is no other BT phone near-by or the old one that has paired with the car previously. There is also the maximum number of devices you can have in the BMW BT sharing. If you reach the max, you may have to clear the car BT pairing memory by removing the power to the BT unit (by removing a fuse in the rear fuse box). The info is in the manual and inside the fuse box (which tell you which fuse is for the BT.)
Feb 06, 2013 | BMW X Series & X5 1997 >2006
Connecting TLWR743ND to BT hub
I spent ages trying to use tp- as an ap client. tried every setting I could think of. Then........ Changed wireless security setting on home hub 3 to use JUST WPA2 not WPA/WPA2 and all worked. Give it a go. :-)
May 04, 2012 | TP-LINK Router TLWR743ND 150Mbps Wireless...
Pairing blackberry with MEX-BT3700U
Place MEX BT in the search mode (Hold down BT button until BT logo begins to flash) Put BB in BT search mode, When BB will identify the BT device as "XPLOD" when prompted enter on BB "0000" and enjoy.
Mar 24, 2009 | Sony Car Audio & Video
BT ADSL prob: ATM OAM F5 segment ping - OAM F4 FAIL
are you using the router through a BT line? if you are BT will be able to sort this problem for you by sending the router an update that it sounds like it needs
hope this helps
Nov 20, 2008 | Computers & Internet
Jabra A7010 BT hub will not pair with Sprint BT headset
Have you tired to pair your hub with any other non-Jabra headset? I am trying with Plantronics Voyager 520 without success ;(
Jun 03, 2008 | Radio Communications
Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
Jan 11, 2008 | Motorola Mobility Bluetooth...
Just Wireless Bluetooth Headset Wireless Headset Logo
Top Just Wireless Radio Communications Experts
Marvin
Marvin
robert
Don Eagan
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
