SOURCE: Forgot Digital Combination of Sentry Safe Model #SO500
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
They should be able to help. I would try calling first, to avoid paying the $12 to retrieve the combo, but with the serial number of the safe, they SHOULD be able to help you over the tele.
SOURCE: defalt code for sentry safe 5 digits
You'll need to go here:
There is no "default code", but they do keep the serial number and code on file, for just this purpose.
SOURCE: sentry safe V530
may have been 8 bucks , but it's 12 bucks now.
check out www.sentrysafe.com ,
look on right side menu for "keys" and/or "combination" .
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
SOURCE: I lost the combination for my brinks home security
Hi, You can contact Honeywell at 1-800-223-8566 . They are providing support for Brinks safes.
