SOURCE: Water is not draining?
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
SOURCE: my ge wsm2700dawww stack washer will not agitate or spin
Hi
Please find the links bellow to diagnose your problem…since your problem to the washing machine can be caused due to various reasons.Please go through the article to have an in-depth knowledge to your query…
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntspin
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntagitate
http://www.geappliances.com/search/fast/infobase/10002166.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
SOURCE: GE WSM2700DAWWW dryer squeaks
When the felt on the front tub guides wears off it will squeak. It can be replaced by part 1220 and 1221 on this diagram and parts list. Take off the front panel along with the door to access it.
There is a ball and socket bearing at the back of the drum but it doesn't usually go bad. If you need to get to it, go in from the rear of the dryer behind the heat coils. 1212 is the bearing housing.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5221980&diagram_id=22300825#d22300825
SOURCE: ge stackable wsm2700dawww
USUALYY FRONT DRUM GLIDES AND REAR BEARING ASSYMBLEY PARTS ARE MADE OF TEFLON AND THEY WEAR OUT
