Microwave Ovens Logo
A
Anonymous Posted on Jul 02, 2014
How do I remove kitchen aid (microwave oven: model kcmss1555 rss) control panel to replace "plastic actuator" lever
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 02, 2008
SOURCE: The door of my Kitchen
The door latch heads (prods) are not making proper contact with the door switches, so it will not work right.
The latch heads need to be replaced.
You can order parts for this Canadian model here.
We're happy to help and we appreciate your thoughtful rating of our answer.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jun 11, 2009
SOURCE: Microwave turns on & control panel is frozen. F2&PAN error codes
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number (KHMS155LWH1 without dashes) from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Aug 04, 2009
SOURCE: Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Anonymous
  • 5911 Answers
  • Posted on May 22, 2010
SOURCE: How do i replace door handle
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The part number for the model number you provided varies depending on color, so make sure you order the correct one for your oven. You can view an exploded view of your microwave door here:
http://pcappliancerepair.com/model-display.php
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
If you have any questions, please post back and let me know. I hope this helps you
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 26, 2010
SOURCE: Display panel (right side) on
The first thing I would do is a hard reset (simply unplugging it for a couple of minutes) if that has not been done already.
Then one would need to retrieve the technical sheet (mini-manual) found behind the control panel assembly.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here. Just enter your model number from the tag on your unit.
If a reset won't fix it, I would bet there is a loose connection where one of the boards connects to another, or some contamination from grease or steam, etc., at one of those connectors.
A lot of time one can unplug then reconnect the connector, and that will clean it. Or one can unplug the connector and clean the contacts with a soft pencil eraser.
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Error code F2
Per the tech sheets (page 8), "F2" error code means "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too. Not the best recommendation but we have to follow it.
- The part number for the touch panel (aka a membrane switch) is AP3130765
- The part number for the control board AP3130764
Here are the break down diagrams for the Kitchen Aid microwave Model KHMS155LSS4
Gene.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Read more: http://forum.appliancepartspros.com/microwave-repair/19054-kitchen-aid-microwave-error-code-f2.html#ixzz3bRus7JKM
How to repair kitchen aid door springs
proceed according and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
1helpful
Kitchen aid micro wave change fuse
Unplug, remove top, look under keypad, follow wires to circuit board, look for a silver rectangular capacitor, "may be under a plastic flap" discharge capacitor with a screwdriver across the 2 points, look for a small fuse near by in clips, remove and replace with same current rating, assemble before test because lethal voltages present when powered.
Kitchen aid khms147hss0 microwave - handle broke and gray plastic ( has 3 screws) on perimeter of door itself cracked - was going to replace complete door - how do you replace the complete door - remove...
Door parts are available separately on this model.
The parts manual is here. And you can order parts here.
You have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
3helpful
2answers
How do you replace the fuse in a microwave oven.
Be sure the oven is unplugged or the breaker is off.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Let us know if we can help further.
7helpful
2answers
Kitchen aid microwave oven not working.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I'd say you have a contaminated or failing keypad or possibly residue on the boar dor where the keypad connects to the board.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
