Question about Life Fitness 9500RHRT Recumbent Bike
Where is battery on life fitness recumbent bike 9100
5 Suggested Answers
SOURCE:
SOURCE: Life fitness recumbent bike problem
Hi
We had exactly the same thing. If you take the covers off you will find a black battery pack in the bottom. It is about the same size as a cordless drill battery. We got a replacement from Maplins - cost about £10. It works perfectly now.
Posted on Jun 17, 2009
maxtreadmill
  • 832 Answers
SOURCE: My Life Fitness 5500R (like 9500R ) Recumbent's
sounds like the keypad is not functioning since this is one of their older model I recommend call Life fitness and see if parts are available their # is 1-800-351-3737 they will probably will ask for a s#
Posted on Mar 01, 2010
maxtreadmill
  • 832 Answers
SOURCE: Our life fitness 9500hr recumbent bike stopped working
If this unit has not been used for that period of time then the 6v batt has died ans needs replacing call National Gym Parts @ 1-800-496-7278 to order part# LC001.5
HERE IS THE PROCEDURE TO REPLACE THE BATT:
Tilt the bike on its side, remove mounting screws securing the battery to the bracket. Remove the battery just enough to access and disconnect the black (neg) wire from the (-) terminal and the red (pos) wire form the (+) terminal. Replace battery and reverse procedure when installing battery
Posted on Apr 17, 2010
  • 11 Answers
SOURCE: i have a life fitness
Usually a faulty lower circuit board - remove and replace or call a local service tech.
Posted on Apr 27, 2010
Lifefitness recumbent bike battery not charging
Possible causes for a dead battery or it not holding charge
1. Battery has lost its ability to hold a charge (dead battery)
2. Charging system on unit has failed (battery cables, alternator, or alternator control board)
3. Stuck key on the display is causing a constant draw from the battery.
For any further troubleshooting you can contact our Technical Support Team and we would be happy to help you,
online or by phone 888-713-2880 or
http://www.sportsmith.net/supportsearch.aspx
Aug 16, 2014 | Life Fitness 9500 HR Recumbent Bike Next...
How do I remove the pedals on a 8500 life fitness recumbent bike
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Using a wrench, you remove the left pedal as you would loosen a normal, left hand threaded bolt. The right side is a reverse thread and would need to be loosened in the opposite direction.
Feb 20, 2013 | Life Fitness Nut Lock, Cranknut, Lifecycle...
Apr 17, 2010 | Life Fitness 9500RHRT Recumbent Bike
My Life Fitness 5500R (like 9500R ) Recumbent's display works but when I press the program button it doesn't cycle through to Hills, etc.! Suggestions?
Feb 28, 2010 | Life Fitness 9500RHRT Recumbent Bike
DOA Life Fitness 9500rhr exercise cycle
You should check your battery-it must be putting out at least 6 volts to get the computer started up-depending on the era there will be a battery near the bottom frame-you will need to remove on of the side covers to reach it-
Dec 27, 2009 | Life Fitness 9500RHRT Recumbent Bike
Hi
Jun 16, 2009 | Life Fitness 9500RHRT Recumbent Bike
Can't get any power running on my 5500 hr life cycle
You have to start pedaling to get it to start up, some times you have to pedal pretty fast to get it to start up
May 27, 2009 | Life Fitness 9500RHRT Recumbent Bike
Life Fitness 9500RHRT Recumbent Bike Logo
Top Life Fitness Exercise & Fitness Experts
Vincent_G
Vincent_G
Craig Butler
Craig Butler
Android Man
Android Man
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
