SOURCE: Full Waste Toner Bottle in Lanier LD040
Hello sir; I believed you talking about LD045, am I right? In this model it doesn't have waste toner bottle, the only place you can clean is imaging transfer unit, after you cleanup the message will be disappear.
SOURCE: lanier LW324 waste toner bottle full
Open the machine and to the right under the drum you should see the the black powder (toner) going down into container the right lower side cover must come off. probably a service call will be needed
SOURCE: Where can I locate a drum for an old Lanier 5235
Your Lanier is made by Ricoh and is a model Aficio 355. The drum and drum cleaning blade is still available and not too expensive at about $200 for the pair. You can find these with all the related info at precisionroller.com Great people to deal with and I order a LOT of stuff from them.
Their part numbers are P8150 for the drum and C5950 for the cleaning blade.
Good Luck and Thank You for using Fixya.
