SOURCE: JVC KD-G430 problem setting the time
You can download the manual from the link below: http://books.jvcservice.com/booklist.asp?Model=KD-G430 The time setting is on page 13. Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: how to set the displayed time in JVC KD-G110 car music system?
i couldn't able to set the time in my radio if possible can u please help me Thank u
SOURCE: How do I change the time on my JVC KD-G230 stereo?
its simple. hold the "sel" button until the menu comes up and it will say hours use the volume button to change it. then use the next button to go to the minutes. then you can also change other settings under this menu. hit the "sel" button again to go back.
SOURCE: i need to set the clock on my jvc kd-g340 car stereo
make sure radio is on and you press and hold sel (select) button
when you see demo release the select button(you might see other option if you have access the menu options). then press the forward button until you see clock h (hour). to adjust turn volume knob. then press the fast forward button again to get clock m (minute) and use volume knob again to adjust minutes. once you are done make sure to press select again to save the time.
SOURCE: is jvc kd-g335 blue tooth compatable
If it is a "Ready for BlueTooth" model you will need this adapter JVC KS-BTA20
